Originally Posted by blaster2
Hi i just picked up a blaster 2 this past summer and only rode it a couple of times. I would like it to have better throttle response when im jumping waves. Any suggestions on what performance parts i should get for it??
Thank you.
hey, nice little ski you picked up there.
first things is to get a good scoop grate and ride plate. a good pipe will help alot with bottom end response for sure.
factory performance would be the way to go. good luck finding one though. you can use one from a blaster one as long as its the mod chamber. the limited chamber i dont believe will fit the blaster 2.
its unfortunate that they didnt make alot of parts for that ski. i guess because they only made it a couple of years.
the 760 is a good motor and makes good power. the port timing is a bit high for the bottom end it your looking for.
if you really want to wake it up add a good ada, or protec head to it and get the compression up around 180. that, with a good pipe and prop will make all the difference in the world for that ski.
feel free to pm me with questions, of if your looking for any a/m parts for that beast!
thanks, dave
providing parts & service to the pwc community for over 10 years.
check out my feedback and buy with confidence!
WE CARRY ENGINE TECH,SOLAS, THRUST INNOVATIONS,JET PILOT, PROTEC, LYNN VICK, BLOWSION, IMPROS, ADA, R&D, WORX, UMI, JET DYNAMICS, SHREDMASTER, TORX RACING.
BEST PRICING ON PROX PISTONS, CYLINDER BORING, CYLINDER RECHROMING.
NEW AND USED PARTS AVAILABLE
