Where Can I Get A Vts??? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Go Back   PWC Forum: The best hang-out for Personal WaterCraft enthusiasts > PWC General Discussion > Aftermarket Performance
Old 12-04-2007, 02:02 AM   #1 (permalink)
Exclamation Where Can I Get A Vts???
WHERE CAN I GET A Variable Trim System ?
at fast speeds my jetski hopps along so i was wondering where i can get something to trim it.
electroryan is offline   Reply With Quote
Old 03-12-2008, 03:32 PM   #2 (permalink)
REMY's Avatar
what ski do you have?
00 gp12r triple piper.... everything except 05 pump
03 gp13r stock...
00 gp13r BB custom +
03 crf450r
REMY is offline   Reply With Quote
Old 03-12-2008, 11:17 PM   #3 (permalink)
Default 95 seadoo spi
my ski is a 95 seadoo spi
Old 03-12-2008, 11:56 PM   #4 (permalink)
REMY's Avatar
well i dont know much about your platform but, i would imagine if you dont have any trim at all then you would have to modify your nozzle, and modify your bars to hold the vts grip,, there might be a kit with a nozzle in it but ive never looked ..
have you heard of an auto drop nozzle,, it trims down when you turn automatically, and can be set at any posotion when the bars are straight ahead.... you dont need any grips or trigger for this, so no drilling.
theres also a spring loaded drop nozzle setup thats manually activated by a trigger on the bars...
i only give these suggestions cuz putting vts on your ski might be pricey...
other than that do you have your plate angled? have you messed with the tab?s..... you might be able to fix the hop without needing trim.
03 gp13r stock...
03 crf450r
Old 03-13-2008, 03:01 AM   #5 (permalink)
i really dont know much about my jetskia nd what the plate is and all that. its stock. i was just interested in sumthing cheap to put on to stop the hopping at higher speeds
Old 03-13-2008, 11:16 AM   #6 (permalink)
REMY's Avatar
put a washer under all the bolts of your trim tabs.....(the flat metal tabs on either side of the plate)... this will help with the bounce,,, test it then tell us if it helps... trim would not be a cheap alternative
03 gp13r stock...
03 crf450r
