Remove Bendix from '93 Polaris SL650
Sorry, probably should be in Polaris Thread...will try to correct!
Help! My PWC won't start, i removed gas and oil, all exhaust including manifold and got the starter out. Starter motor is fine. I was surprised to see the bendix is housed inside the housing for the flywheel. My CD repair manual only talks about removing the flywheel housing cover AFTER pulling the engine from the water craft.
Has anyone replaced the bendix, can I get those covers.looks like two layers of them from the front of the engine without pulling the engine out?
Once I get the covers off, does the bendix need a puller or does it come off by hand, doesnt appear to be bolted???
Finally for reassembly, I have torque values but which surfaces need gaskets or permanex? As you can tell, i am not a mechanic and this is the first repair this machine ever needed.
