Go Back   PWC Forum: The best hang-out for Personal WaterCraft enthusiasts > PWC General Discussion > Freestyle / Freeride Forum
Old 06-29-2006, 02:30 AM   #1 (permalink)
WaTeRhAwK
Default 550 freestyle ski....
Does anyone have any older 440/550 skis they want to modify for freestyle?
WaTeRhAwK is offline   Reply With Quote
Old 06-29-2006, 10:49 PM   #2 (permalink)
motobro45
Default help
I have a 81 440 that i just put on new pistons and a 40 over 550 cylinder
performance exhaust, one problem thow, it will not run. is it possible i need
reeds in this engine now or something else. ign. intake gas compression ok
cant figure. can u give me any suggestions
motobro45 is offline   Reply With Quote
Old 07-10-2006, 02:31 AM   #3 (permalink)
WaTeRhAwK
Well, There are no reeds in a piston port engine.
if it's getting good spark, fuel, compression, and it's timed right then it should start and run with no problem. There are a ton of things that could be keeping it from running...
too rich of fuel on the low speed needle flooding it out.
weak spark, not hot enough to ignite the compression.
Bad crank seals causing a case leak.
Bad fuel pump on the carb.
I really need to know a lot more about your setup to narrow it down, can you post a picture of your engine compartment and your carb(s)?
Old 08-23-2006, 01:19 AM   #4 (permalink)
Snackem
I do not have one yet however I know a gal that is selling two 550 kawis on a double trailer for $750. If I have not found a better deal (on a superjet or an X2) than that by this comming winter then I will purchase them. Any ideas on what kind of mods to do, I am thinking: Blowsion Kickers, a Pipe and maybe an Solas Impellar? any suggestions?
"Son, remember, no matter how hard you try you can't polish a turd."
--Gene Lanthorn
Snackem is offline   Reply With Quote
Old 08-23-2006, 08:41 PM   #5 (permalink)
JUST-IN-TIME
JUST-IN-TIME's Avatar
Talking 550
#1 would be better carb if pre 91 ski and intake with arrestor
#2 ride plate/intake grate
#3 turn plate
#4 exhaust Mani and full or half pipe
#5 prop
#6 steering nozzle
TRUE JACKASS FISHING REPORTS
Old 08-24-2006, 12:27 AM   #6 (permalink)
Snackem
#3 turn plate
#5 prop
#6 steering nozzle
Complete newbie question but what is the difference between the turn plate and ride plate? The ride plate is the same thing as the intake grate I assume, so what is the turn plate?
--Gene Lanthorn
Old 08-24-2006, 12:52 AM   #7 (permalink)
adam.van
adam.van's Avatar
The turn plate is what the handle bars mount to, and usually an aftermarket one will allow you to turn quicker than the stock one. A ride plate is the plate on the bottom of the ski in the back it is behind the intake grate.
adam.van is offline   Reply With Quote
Old 08-24-2006, 09:43 AM   #8 (permalink)
Snackem
Thanks for the infor.
--Gene Lanthorn
Old 08-26-2006, 05:32 AM   #9 (permalink)
JUST-IN-TIME
Talking Parts
THANX MAN
Old 10-09-2007, 11:37 PM   #10 (permalink)
sclocal_420
Default i have a 92 550sx. help!!!!!! i wanna go faster
THANX MAN
how should i mod my 550?!?! i just got it, its all stock. i know i can get more out it, how?!?!
sclocal_420 is offline   Reply With Quote
vB code is On
