Newbie: Finally found the leak, I think
From the water flow regulator valve on my 2005 2 stroke Sea Doo. I can tell that it is coming from there, but I probably need to remove it to verify. One issue that I see is that this is on the cooling water intake and maybe this is a result of the fact that I tested in when hooked up to a hose and maybe this would not result if I didn't have the hose pressure. I am planning to have it in the water on Saturday, so that would tell for sure.
Any thoughts on this?
Chuck
