I pulled EVERYTHING, but the head off. I check all parts, lines, elbows, cylinder walls for sand or obbstructions, but all was in tact. Tried known goodd exhaust pipe, no change. After about 10 mins ride time, heat sensor goes off. Head cover is hot, can boil off water if put onto spark plugs. If I run garden hose thru flush side, it stil has air pockets in head vent tube. If I unhook flush hose, pinch line off to dump at back, UNHOOK jetdrive hose, attach garden hose, there are ABSOLUTELY no air bubbles any where. Even flushing created air bubbles... So can it be bad plastic elbow thru hul at jet pump/high pressure zone? Has new wear ring installed.
