stx1100 rebuild
hey ppl first time on this site
i have a 97 kaw stx 1100 and am currently replacing a driveshaft bearing and all gaskets in the engine
as the manifold was removed i noticed water with oil in the middle section of the crankcase
the engine has been rebuilt by previous owner due to a broken rod cracking the crank case and busting the bores
as i pulled engine out found bits of cylinder bore sleeve under engine suport tray
anyone know of the best place i can get a rebuild kit {states or australia}
any ideas on what i should be looking for and things i should do at the same time whilst all this work
cheers
