Check the compression and rpms the engine is running at. Ideal would be: 120 psi per cylinder and running at 7080 rpms. If you are close to those numbers, then pat youself on the back, because you are in a relatively small group of people that can get close to 300 hours on a 1200 without a rebuild. If you are close to ideal numbers, forget the rebuild and keep doing whatever you have been doing.
The further the compression numbers are from ideal on one or more pistons, the closer you are to a rebuild. Good news is that if you do need a rebuild, it will only require a top end kit at this point, so not too expensive.
