The Yamaha MR1 engine (in the VX, and FX) skis is a modified R1 motorcycle engine.....highly modified. One big Problem with a standard motorcycle engine, is how are you going to cool it (you would have to use a liquid cooled engine)? Also, how are you going to connect the pump.........you need a drive shaft? Plus ski engines do not have transmissions, but gear reduction drives built into the crankcase, because the pump can't be driven but to a certain speed without self destructing. I can't ever see it being cost effective, or ever matching the performance of even an entry level ski.
