Waveraider will not stop starting!!!! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 01-31-2012, 04:45 PM   #1 (permalink)
Default Waveraider will not stop starting!!!!
I was taking my 94 waveraider to the waterway to ride. When the jet ski started the starter keep turning while the motor was running. I had to disconnect the battery cables to shut the jet ski off. When I got home I checked out the wires and solenoid and everything looked fine. But when I put the battery cable on the terminal It starts again.
waverider4life is offline   Reply With Quote
Old 02-01-2012, 05:11 PM   #2 (permalink)
Sounds like something stuck in the start/stop switch. I'd take it apart, clean everything up, check springs, connections, etc.
Old 02-02-2012, 10:02 AM   #3 (permalink)
98yota's Avatar
A shorted start/stop switch sounds about right. Clean and inspect the switch, check the rest of the circuit as well because there could be another short hidding. Luckily these are pretty simple systems so there's not much to inspect. Good luck!
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
