OK, I'd wait until you get the good relay, then try again. If it turns over, but won't start, check for spark. If no spark then it could be bad temp. sensor, bad CDI, or bad stator. I'd check the temp. sensor, and voltage from the stator before buying a new CDI, since they are expensive.
If you are seeing "START" on the display, then I'm thinking it is probably OK. Once the engine starts, the rest of the display should power up.
