engine only turns opposite direction by hand - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-19-2012, 02:58 PM   #1 (permalink)
Default engine only turns opposite direction by hand
yamaha xl800 has only 40 hourspistons are moving up and down freely when i hand crank the engine from impeller.. but only in the opposite direction its supposed to go .. can only get one turn in correct direction and it locks when pistons are at the highest point and lowest point ..it was cranking fine but i had to change the ware ring as impeller was sticking but now i have above problem even with impeller casing removed any ideas on what could be wrong as it was cranking fine the past few weeks??
gange12 is offline   Reply With Quote
Old 07-19-2012, 07:07 PM   #2 (permalink)
Sounds like you got some engine damage. You will need to pull the head and take a look.
Old 07-20-2012, 06:02 AM   #3 (permalink)
if it turns freely in one dirction and the pistons are moving up and down would engine damage not stop it both ways ?? do the seals and gasket have to be replaced to take off the head ?
Old 07-20-2012, 07:36 AM   #4 (permalink)
i am thinking water in the crankcase could be a possiblity .. is this a possible cause ? there was water in the cyliners previously but i blew it out through cranking .. how can i remove water from the crank case ?
Old 07-20-2012, 07:39 AM   #5 (permalink)
Take the spark plugs out and see if turns then. If not you most likely have some damage to a piston that is causing it to not rotate.
Old 07-20-2012, 08:14 AM   #6 (permalink)
spark plugs are out , if the piston was damaged would it not stop rotation in both directions? i am cracking it by hand one direction but its almmost solid the other
Old 07-20-2012, 11:27 PM   #7 (permalink)
My guess is its binding against something broken inside the cylinder. Could be piston catching on exhaust port, etc.. Only way to know is to take it apart at this point.
Old 07-21-2012, 07:38 AM   #8 (permalink)
okay thanks for that .. engines coming out today so im sure ill find out soon enough
Old 07-23-2012, 09:59 AM   #9 (permalink)
Could this not be a problem with the one way clutch on the starter motor if it has one. Just a thought
Biscombe is offline   Reply With Quote
Old 07-26-2012, 04:43 PM   #10 (permalink)
Another post with similar problem reminded me that you could have lost a powervalve. http://www.pwcforum.com/yamaha-jetsk...xlt-800-a.html They sometimes fall loose unless you had clips installed. If they fall into a cylinder, then you get the same symptoms of it not being able to turn completely.
The bendix on the starter will not prevent rotation either way.
