No spark, so I checked the coil and it was bad. Replaced the coil but didn't check CDI and V regulator/rectifier at the same time. The new coil didn't fix the problem - still no spark.
Now I've checked the CDI and V reg/rect and both are bad. In addition both spark plug caps/connectors are open.
The question is could a CDI failure cause the V reg/rect, coil, and both spark plug connectors to fail? I'm hoping it isn't something upstream (i.e., magneto). Thanks for your help.
