If you have water in the engines it is going to have to be drained pronto, or it will rust the cranks. Being that it's a big boat as opposed to a pwc they should be equipped with drain plugs, if not pull the plugs, ground the plug wires and crank the thing over until it clears somewhat, start the engines and burn the rest of it out, spray some WD-40 down into the carbs while it's being cranked, that will dispearse the rest of the water.
you need to take it out to the water and run it and burn the rest of the water out.
