Hello all and thanks in advance for the help
my exhaust muffler hose ripped and trying to find the same one to replace it is turning out to be very hard
I have attached pictures on how it should look
any help would be appreciated
Thank you.
Babbitts online has it listed under exhaust 1, part #62 for 146 and change can't? seem to get a copy of link to post. You can also get the manufacturer part number off babbitts an put it into eBay search and find used.
Hello yes I saw that while I was looking but all my search for it do not show the same part even by using that part number that is why I came to the forum to ask for help.
are you definite on year? have you verified through your hull Number? last two numbers are the year. it should be located on right rear corner of ski, usually below bump rail.
yes , I did also and they all point to that part + location which is correct but try googling / ebay / any other service the part number, part images do not turn up like the one I have, which is driving me nuts. get my point , anyway I emailed babbittsonline and will let you know what they say if you find anything in the meantime, please let me know .
Thanks for your help.
the more I look at your pics and the Babbitts part. I think the one you see on Babbitts most supersede yours. rather than be stepped at the end it appears to have been made one size for the full length.
Yes I think, now its two parts or it was two parts or god knows what, anyway the part on Babbitts and Yamaha is not available till the end of next month so not even worth looking at at the time being.
that being said Im mind blown how I can not find it on the WWW. dunno what I'm going to do now but try to fix it, glue it , at a layer of plastic on top and tie it very tight and hope it does not cause an issue and works.
whats your thoughts ?
Was hoping it wasn't on the bend. If you cleaned it really good with say gas or better yet laqor thinner. Then maybe use inertube cement and a cut open rubber pipe coupling. You'd have to clean both and rough both up with sand paper. And several clamps on it. Maybe it would hold. Don't know.
Thanks for the info man, ya going to take it to my friend, we are first going to glue it with a very strong glue, than get a piece of round rubber similar (one of the ones I bought that were not the part) put it over it and glue it also and tie it with multi rings on it and then wrap with with strong tap and put it on the ski and take it out ... fingers crossed !!!
Related Threads
Personal Water Craft Forum
80.9K posts
37.7K members
Since 2006
