Oil Mix - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 10 (permalink) Old 04-04-2011, 08:01 PM Thread Starter
Oil Mix
I have a 2000 GP1200R,& just installed a oil block.
What is the right oil mixture?
32:1(20oz to 5gal.)or 40:1(16oz to 5gal.)
cubanredneck is offline
post #2 of 10 (permalink) Old 04-05-2011, 06:41 AM
YamaDoo's Avatar
I don't know for sure but I think 40:1 is the way to go. 32:1 seems too excessive
YamaDoo is offline
post #3 of 10 (permalink) Old 04-05-2011, 04:04 PM
Outlaw's Avatar
Lightbulb
Since you have already undone oil injection (????) not sure why, but until you know the mix is right I would go 40:1. It may be smoky since at an idle oil injection is about 100:1, then changes the ratio through out the power band. So by premixing the only time you are at the right ratio is at WOT. Which most two stroke engines are a 50:1 ratio.
Good luck with trying to balance it for all speeds without fouling plugs. You may want a gas mask for start up. They invented oil injection for a reason......
2009 RXT-IS 255 HP
2008 GTX 215 HP
Outlaw is offline
post #4 of 10 (permalink) Old 04-05-2011, 07:46 PM Thread Starter
Everyone that is familiar with this unit knows that one of the main problems is the oil lines come loose & many have blown their engines.
I've done my homework & talked to a few owners.
post #5 of 10 (permalink) Old 04-06-2011, 07:02 AM
Outlaw's Avatar
So instead of replacing oil lines we go backwards in technology and emit more pollution??? Bummer Yamaha
2009 RXT-IS 255 HP
2008 GTX 215 HP
Outlaw is offline
post #6 of 10 (permalink) Old 04-06-2011, 07:12 AM Thread Starter
Anyhow,back to my original question.
Would 40:1 be the right fuel/oil mix?
post #7 of 10 (permalink) Old 04-06-2011, 02:54 PM
Does that model have the powervalves?
I'm pretty sure that the recommended ratio for non-PV Yamahas is 50:1, and for the PV 800 and 1200s it is 32:1. I've seen this info someplace, but can't put my finger on it right now. You should be OK if you do not have the PVs to go 40:1 as a good starting point, then try 50:1 if all goes well.
Ernest T is offline
post #8 of 10 (permalink) Old 04-06-2011, 03:27 PM
OK I found the info on SBTs forum:
Post Pre-mix stock oil ratios
If you have removed your oil pump and gone pre-mix, these are the correct ratios you should be mixing to, after the first tank of break-in. These are the stock ratios the factory pumps put out at WOT:
32:1 = 4oz/gal
40:1 = 3.2oz/gal
50:1 = 2.5oz/gal
Sea-doo
40:1
Yamaha
All but 800 & 1200pv 50:1
800 & 1200pv 32:1
Kawasaki
50:1
Polaris
40:1
Tigershark
40:1
Ernest T is offline
post #9 of 10 (permalink) Old 04-06-2011, 05:03 PM
YamaDoo's Avatar
Your 2000 GP1200r is a powervalve motor so run 32:1 Now I know why my 98 GP1200 just barely sipped the oil. It ran at 50:1. Good info Ernest.
YamaDoo is offline
post #10 of 10 (permalink) Old 04-06-2011, 09:07 PM Thread Starter
32:1 = 4oz/gal
40:1 = 3.2oz/gal
50:1 = 2.5oz/gal
Sea-doo
40:1
Yamaha
800 & 1200pv 32:1
Kawasaki
50:1
Polaris
40:1
Tigershark
40:1
thanks for the great info
Human Verification
