You could tow it. Total weight is going to be maybe 1200 lbs max. with gas and the trailer, but I wouldn't want to tow it far. Towing puts considerable strain on the transmission on vehicles that are not really designed for it, but should not be a problem for short hauls.
I think your concern about getting the ski out of the water at the ramp is the more important consideration. Having front wheel drive will help. But a lot depends on the ramp (angle, how slippery it is, etc.). When I used to trailer my ski, there was one ramp that was very steep and very slippery. If there were any moisture at all on the ramp (rain, water dripping off boats, etc.) then even large trucks would have to be towed back up the ramp, so ramp selection is important.
The other problem with a car is that the back of the car and tow hitch are very low. On some ramps you may find that you would have to submerge the rear end of the car to get the ski far enough into the water to float it.
Scout out the available ramps for the best location, and maybe take a friend along with a truck the first time in case you need a tow. I think you will probably be OK, but you don't want to end up like this:
‪jet ski ramp gone bad car sunk‬‏ - YouTube
