Jump the starter solenoid (2 large wires) and see if it will turn over. If it does you have a bad solenoid. If it won't turn over jumping the solenoid, I'd suspect a bad kill switch. I'd disconnect it and try again. Be sure you have a good battery.
The engine has to be turning over to have spark. No use checking CDI, stator, plug wires, etc., until you get it turning over, in fact, you can't check anything else until you get it turning over. If its not turning over there are 5 possible components to worry about: battery, starter solenoid, starter, wiring, kill/start switch. Unless the engine is locked up it has to be one of these. If you check all these and it still won't start by jumping the starter solenoid, then pull the spark plugs and see if you can turn the engine by hand. Did I lose you?
