Aquatrax leaking oil into water - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 11-27-2011, 08:17 PM   #1 (permalink)
Default Aquatrax leaking oil into water
I have a 2005 3 Seat turbo charged GPS aquatrax that is leaking oil into the water the last three times that I have slid it off the slip. The ski appears to run fine with about 200 hours. I have checked the oil level several times and it does not appear to be noticeably decreased. Please explain my problem to me as a two year old since my mechanical abilities are fairly limited. Any help or insight would be greatly appreciated. Right now the ski is in a heated garage and probably will not be serviced until March/April. Thanks for your time.
hoosiervet is offline   Reply With Quote
Old 11-30-2011, 04:21 PM   #2 (permalink)
I flushed my ski today that I thought was leaking oil into the water and I am now certain it is carbon from the exhaust. It accumulated on the water initially when i first started flushing the engine today and eventually stopped altogether. Does that mean it is running too rich? Do I need to have the valves adjusted? Do you think it is a problem with the exhaust poring into the turbo charger?
Again, any help with this problem would be appreciated. Thanks.
Old 12-14-2011, 04:04 PM   #3 (permalink)
glockm22's Avatar
Their isn't anything wrong with this, you will get carbon build up from the exhaust. One thing you can do to help stop the build up is to make sure from time to time you add a can of sea foam to your fuel, this will help in keeping the exhaust clean and help with carbon build up. Your doing what your supposed to be doing by flushing out your machines after their ridden.
-- Confucius
