change oil - Page 2 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-18-2009, 08:33 PM   #11 (permalink)
That is what needed to be said all along. Thanks, I was too busy griping to answer the question.
1995 DJ is offline   Reply With Quote
Old 07-19-2010, 01:09 PM   #12 (permalink)
jam019's Avatar
Default Rude people
Just help the guy out for heaven sakes. Dont be Rude..
jam019
jam019 is offline   Reply With Quote
Old 07-30-2010, 08:03 AM   #13 (permalink)
mabtek's Avatar
Default cheap oil pump, how to change yr oil
Ok, get this pump,
Multi-Use Transfer Pump
cheap, only 6 bucks, works great! have changed my oil many times with this pump.
warm up the ski, hook up to the flush kit, run for a couple of minutes.
pull the dip stick, wiggle the hose in there as far as you can get it. pump until you get no more.
tip the ski up slightly, not to high or the oil will run out when you remove the rear oil plug.
add the smallest hose to the pump, pump this area till no more comes out.
put the plug back in.
Get yourself a rag and put it below the notch where the filter is located.
remove the filter.
Take the new filter, dab some oil on the seal, screw the filter on , HAND TIGHT ONLY.
Add 4.5 Quarts, level out the ski, start the ski, run for a minute or two, and check the dip stick. add if needed.
Load up and get on the water.
06 R12X Macsboost, filter, wedge, IC
04 F12X
mabtek is offline   Reply With Quote
Old 07-30-2010, 12:33 PM   #14 (permalink)
ya, this forum sucks i'm going to greenhulk too.
DBINX is offline   Reply With Quote
Old 08-16-2010, 09:18 AM   #15 (permalink)
Im a newbie ski owner and this helps alot, I have 2 boats and it seems to work very similar to an old boat I had
r12boost is offline   Reply With Quote
