Does anybody know the hp on these?
They sound sweet
The world's first production turbocharged four-stroke, three-seat personal watercraft continues to dominate. And its features continue to impress; 1235cc turbocharged four-stroke engine, off-throttle steering system, selectable speed limiter and electronic keyless ignition.
Engine Type 1235cc liquid-cooled dry-sump inline four-cylinder with intercooled turbocharger
Bore and Stroke 79.0mm x 63.0mm
Compression Ratio 8.5:1
Valve Train DOHC; four valves per cylinder
Carburetion PGM-FI with automatic enricher circuit
Ignition Computer-controlled digital with three-dimensional mapping
Length 120.5 inches
Width 45.7 inches
Height 40.8 inches
Dry Weight 746 pounds
Fuel Capacity 16.6 gallons with low-fuel warning
Pump Axial-flow single-stage 155.0mm jet pump with reverse
Hull Fiberglass reinforced plastic (FRP) outer hull, inner hull and deck
Storage Capacity 5.8 gallons
Seat Length 33.1 inches
