It sat over the winter in the garage with about 1/4 tank, I added some treatment to it and filled the rest up with new gas. I'm hoping it is the gas, but I can remember last season it did it once, but then again that was at the end of the season so it could be the same gas???
It idles right where it should, but like i said the rpm dip too low causing the stall when I go from WOT and immediately let completely off the throttle. It seems like it just needs to be adjusted??? I gotta check the plugs tomorrow and see what they look like.
