Originally Posted by seadub2
Howdy,
Will WD-40 work for this application, and is it OK for the other maintenance stuff like spraying the components and lubricating the wastegate linkage?
WD is ubiquitous and easier to handle. Besides I've used it on all my Japanese bikes and my Harley with no problem.
What do you think??
Thanx...C.W.
I'd be careful spraying WD40 around the inside of a ski. It is as much a solvent as a lubricant. It does displace water, but tends to leave behind a residue that may cause problems later on. It causes plastic and rubber to deteriorate over time, and there are plenty of those parts in a ski. It also can foul electrical connections over time. CRC or Crossion X are much safer products for use inside a ski. Both carry a heavy duty version that works well for marine applications and stays in place a long time.
I'd also be careful using WD40 on your bike. Many recommend not using it on bike chains or other components, because the solvents in WD40 actually strips away the lubricants on larger parts like chain links, and leave the chain less lubricated than if you put nothing on it at all.
