f12x no power - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-02-2009, 08:50 PM   #1 (permalink)
Default f12x no power
2003 f12x with 100 hours on it. When it is on the trailer with the seat off it revs just fine but on the water it wont rev up past 4500 . Is there an air filter that im not seeing ?
pookcat is offline   Reply With Quote
Old 09-05-2009, 12:24 AM   #2 (permalink)
How about in the water? Is the limiter on? Yes there is an air filter in a large intake box. Check your oil level too......when warm.
Old 09-19-2009, 09:55 PM   #3 (permalink)
there is no air filter in the box it looks like it disintagrated
Old 10-15-2009, 11:24 AM   #4 (permalink)
CelticCrew's Avatar
Check the air inlet side of the turbo to make sure that little turbine can spin freely inside the turbo. If not use a deep 9mm to loosen it. My turbo was stuck and had the same symptoms.
CelticCrew is offline   Reply With Quote
Old 02-22-2010, 08:29 PM   #5 (permalink)
glockm22's Avatar
Make sure your always using CRC or something comparable on the turbo. Spray it down well. This will help from the turbo and wastegate sticking on you. I also like to run a can of SeaFoam from time to time in the fuel to help with fouling in the engine and exhaust. Good Stuff.
-- Confucius
