Hi, I just got an 05 Yamaha GP1300r with 60 hours on it and it's in mint condition. Had only been run in Lake Ocheecobee so the engine bay looks like it's brand new...Zero corrosion!! Compression is 112.5 in all three cylinders. I know the milage won't be anything like the fourstrokes but cruising at the same speed and condions as the guy posted above me with the Honda, what can I expect to see? What would be the average range? I am taking it out on the ocean this coming Tuesday. Wish me luck. I also sprayed the engine and all the accessories that were metal with that T-9 corrosion protector to help prevent corrosion. Other than flushing the engine and hosing everything down with fresh water, is there anything else I need to know for after use in salt water? I greased the bearing at the bulkhead going to the back bulkhead with some marine grease, are there any other grease fittings that I should know about? I don't have the manual yet. Thanks in advance for the response.
Steve
I just realized that I am in the Honda forum, sorry, don't bash me too hard.
