Originally Posted by Turboski
does that mac boost thing adjust for fuel when it adds the boost? is it just a plug and play?
My understanding of the module is that it essentially attenuates the signal of your manifold pressure sensor; It tells the ECM you have less boost than you actually do, thus allowing the waste-gate not to open until a higher manifold pressure is reached. This does result in higher power output and all other fuel management features remain enabled. Since Honda is notorious for down rating motors, the long term added wear is likely minimal.
Since I love to beat on my F-12X all day everyday and typically burn 10-15 gallons a day I chose not to add it - I'm blowing through enough fuel as it is!
This forum seems REALLY quiet, but perhaps someone else will chime in here as well.
