2006 Honda F12 makes growling noise - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-05-2010, 10:15 AM   #1 (permalink)
Default 2006 Honda F12 makes growling noise
I have a 2006 F12 that makes a growling noise after about 100 ft when I take off. When I let of the sound goes back to normal it is also intermiten sometimes.
dwight is offline   Reply With Quote
Old 07-08-2010, 04:40 PM   #2 (permalink)
glockm22's Avatar
Have you check the Prop? Look into the pump area and also lay on your back up under the ski and look into the grate making sure their isn't anything lodged up their, had a customer with a stick stuck up in his. Kept telling me about the same thing, then I layed up under the ski and pulled the stick out that was lodged in the pump, as he gave it more power it bowed or something and made a terrible growling noise. Make sure you grease the drive line also at the grease zert.
-- Confucius
Old 07-11-2010, 04:11 PM   #3 (permalink)
X E Ryder's Avatar
Cool Glocks right
Bizarre performance and sounds often mean blocked/restricted jet intake.
X E Ryder
2007 Aquatrax F12x
X E Ryder is offline   Reply With Quote
Old 07-14-2010, 06:36 PM   #4 (permalink)
glockm22's Avatar
Have you found the problem yet?
-- Confucius
