2006 F-12x what is acceptable compression? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-19-2010, 02:58 PM   #1 (permalink)
Default 2006 F-12x what is acceptable compression?
Looking at a used (18 hour) aquatrax. Wanting to find out factory acceptable compression range. actual cyl 1 175psi, cyl 2 170psi, cyl 3 175psi, cyl 4 160psi. Just a little gun shy buying used. Recently cooked my 1999 Yamaha xl 1200 having 98-115 psi compression with only 62 hours on it.
Thanks for your input.
KubotaKid24 is offline   Reply With Quote
Old 08-04-2010, 04:01 PM   #2 (permalink)
Usually after being run for a while and the throttle WOT with all the plugs removed, you should have at least 190 from what I remember. Lower readings are frequently salt water corrosion in the valves from water intrusion.
Old 08-19-2010, 06:51 PM   #3 (permalink)
glockm22's Avatar
I'm pretty sure that the manual calls them for 171psi for compression. and 180psi on non turbos
-- Confucius
