wastegate comes off !!!!! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-10-2010, 09:48 PM   #1 (permalink)
Default wastegate comes off !!!!!
so with all te work finally got exhaust housing and manifold off we loosened the engine bolts enuff to move engine a bit slide out exhaust attched to the turbo housing
then we removed the wastegate with a 30mm torx unpried the waste gate cap which was spinning it shouldnt have that meant the ballon type thing in there was busted we now must replace or fix it
ill post pics of wastegate in a bit can anyone help maybe we need to replace the solenoid ????/
ok ok.......we have done research and now found out you can replace wastegate actuator
but yyou must be a lil techkie were working on getting parts and will let yoyu guys know how we doing any ???? or if you want service manual hit us up!!!!!!!!!!!!!!!!!!
wastegate comes off !!!!!-2010-08-10-14.39.00.jpg   wastegate comes off !!!!!-2010-08-10-14.39.51.jpg   wastegate comes off !!!!!-2010-08-10-14.40.07.jpg   wastegate comes off !!!!!-2010-08-10-19.42.53_hempstead_new-york_us.jpg
BIGVOD is offline   Reply With Quote
Old 08-13-2010, 07:29 PM   #2 (permalink)
You say you have access to online service manual? Where?
What problem did you have here? Your turbo is gone?
bryanfx12 is offline   Reply With Quote
Old 08-15-2010, 03:57 PM   #3 (permalink)
My wastegate actuator went bad causing a big deposit of carbon on the turbo causing the turbine not to spin ,,,i just ordered a new wastegate and a ots valve solenoid cant wait to get items so i can post the fixxxxx
for all you guys
pm with your email so i can send you service manual
Old 08-19-2010, 04:12 PM   #4 (permalink)
Are you sure that your problem is the wastegate? The heatshield between the turbine wheel and the turbo cartridge can distort and cause the turbo to drag. If the turbo drags it will pump oil out the exhaust and intake compression seals since the ceramic ball bearing turbos have no oil seals in them like a bushing turbo. Do not take your turbo apart by pulling the compressor wheel, we have not found anyone who is willing to rebalance them and they will destroy themselves at the 150K RPM they turn.
Old 08-19-2010, 06:45 PM   #5 (permalink)
glockm22's Avatar
allot of corrosion , do you ride in saltwater alot?
-- Confucius
Old 01-04-2011, 03:10 PM   #6 (permalink)
Question! where did you find a wastegate to replace that one? mines shot too but turbo is good and i cant find where to buy the WG. honda told me i need to get the whole turbo but that is stupid if thats not the issue. i dont get why they want you to pay 3100 for a turbo just when a 100 wg part went bad and they do go bad! please let me know thanks
Turboski is offline   Reply With Quote
Old 03-06-2011, 06:54 PM   #7 (permalink)
jtracc's Avatar
you cant get a wastgate without buying a new turbo or a used one and taking the wasgate off it. not sure how he got a new wsg only...
03 Honda Aquatrax f12
jtracc is offline   Reply With Quote
