need honda help!!!!! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-18-2010, 11:34 AM   #1 (permalink)
Default need honda help!!!!!
I have a 2004 F12X and after ridding for an hour or so hard it starts flashing "F1" or "FI" i cant tell if its a 1 or I. it causes the engine to loose RPMS and not run as fast. any help would be great!
krazy02ws6 is offline   Reply With Quote
Old 08-19-2010, 04:02 PM   #2 (permalink)
There is a way to read the codes that is posted on some of the other boards.
I would try some high octane fuel and see if you still have the problem.
Old 09-26-2010, 11:47 AM   #3 (permalink)
I had this issue on my F12X and it turned out to be a sticking waster gate. The FI indicate a Fuel Injector issue which was not the problem in my case - it was a very big distraction since I thought I had an intermittent fuel injector and spent a lot of time swapping things around!
Make sure the waste gate moves easily and lube it after each use.
Peter House is offline   Reply With Quote
