2002 honda aquatrax f12x turbo rev limit - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-05-2010, 07:49 PM   #1 (permalink)
Default 2002 honda aquatrax f12x turbo rev limit
i just bought a 2002 f12x with a turbo when i first got it, it would run at 6100 rpm and run 61mph but the longer i ran it the lower the rpm got. now it only goes to 5500 rpm before the rev limit kicks in and 51mph at 3/4th throttle it just seem like the rev limit kicks in so fast not even at full throttle. any clues on what i can do to make it run better???
jona806 is offline   Reply With Quote
Old 09-07-2010, 01:56 PM   #2 (permalink)
First, buy a set of plugs for it, they have to be ordered from Advance Auto Parts or O'Reileys for $11 each. While you are there buy a can of Sea Foam and put it in the gas tank with a fresh load of good 93 octane [Chevron or BP].
Make sure it is not overfilled with engine oil [4.5 Quarts max].
Old 09-09-2010, 07:02 AM   #3 (permalink)
thanks for the input. i'll check the oil level nd get so plugs. Also when i had three people on it the other day it work only go to 4000 rpm is that just because of the weight???
Old 09-09-2010, 07:58 AM   #4 (permalink)
No,it should turn close to 6K RPM even with 3 people on it.
