sounds like it is hitting rev limiter at take off - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-14-2010, 10:34 PM   #1 (permalink)
Default sounds like it is hitting rev limiter at take off
i have an 07 honda 12X and when i take off it sounds like it is hitting the rev limiter for a few seconds. its just like if you were to put a car in neutral and hit the gas!! but it only does it for a couple of seconds!! is this normal?? if not what can it be??
kingmayaya is offline   Reply With Quote
Old 10-18-2010, 11:24 PM   #2 (permalink)
How hard are you launching? and you can see if it is by checking the tachometer.
6atenza220 is offline   Reply With Quote
Old 10-19-2010, 07:44 AM   #3 (permalink)
Modifying the stock intake grate by removing two of the bars from it will help a lot and allow room to get your hand inside to remove debris from the impeller. You can also just buy a Solas aftermarket grate from Iboats.com which will slolve the problem too.
