ok so i ended up taking this thing all a part tonight.....
first off couldnt get it turned over and so i took the starter out and it had power and worked out of the motor on a charger so i put it back in and put power right to it and it still wouldnt turn the motor....(starter shot? not even amps to power anymore?)
next the throttle was stuck so i took that all apart and the trottle body blades are so gummed up they wont move you need to push it with your finger and it stays....(whats the best way to free these up and so it will not happen again? soak them? take apart? and if i do that will the TPS get messed up?)
so then i notice the turbo has oil in it but spins fine and all so when i took the starter out oil poured out of the hole up there! guy before me must have never drained it right or kept adding? i dont know why it has so much. i even took the cap of the oil fill in back and oil pours out and over flows!
so i also ended up taking the turbo off because when this one ran the guy said 40 was its top speed and i seen the turbo was all rusted and the WG would not even move at all so im guessing it was just running off the motor no boost. ( where do can i get a new WG and how much? would a universal style work or adj one? what are the specs or # on this one?)
i did take the valve cover off and it was all clean and looked good and plugs looked ok no oil on them so im guessing...a new starter, oil change, plugs, WG, and clean throttle blades and it should be up and going.
