Hello, I am new to the forum and have done some extensive reading, thanks to everyone for all the info available here. I am ashamed to say I have been doing some things wrong as I did not read my owners manual.
I bought the ski used last year, it is an 03 it currently has 38 hours on it. It was bought new in 09. I last rode it a couple of months ago then it sat. I didn't realize the issue with the gas going bad so the first ride after it sat it was bogging down. It's almost like it is running out of gas it will go fine then bog down then go then bog. You can play with the throttle and keep it going by avoiding keeping the throttle wide open.
After that ride I read about the fuel and used some fuel cleaner as well as fuel stabilizer, after about an hour or so it pretty much ran great with a couple of instances of bogging down. As I was getting off the water after the last ride the fuel warning came on.
Went out the next day and filled it up with gas, now it's right back to the same problem but even worse then the first time.
I know from reading the posts I need to check the spark plugs and make sure my gas tank is not contaminated. I am just hoping to get some opinions about a few issues.
When starting up the ski it had a pretty good amount of bluish smoke, not a lot but something I have not noticed before. Also the tail has a pretty good amount of what looks like carbon on the tail.
Now to my mistakes
I was not allowing the ski to warm up pretty much just taking off and giving it all it's got.
Second my husband usually flushes the ski but I did it the last time before it sat and I turned the water on before the engine. Not for long maybe a couple of seconds.
I have it at the dealer and based on the black stuff on the tail which I think is carbon he thinks the rings could be bad. I just have a hard time believing it could be that based on such low hours. Does anyone think I could have blown the rings by flushing it for just a few seconds like that? Do the turbos go bad at such low hours? Could the smoke be from the cleaner? Any opinions are greatly appreciated.
I also have an 05 non turbo that sat the same amount of time and it runs fine.
Thanks so much in advance!!
Angie
