2004 aquatrax f12 trouble - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-24-2011, 04:05 PM   #1 (permalink)
Default 2004 aquatrax f12 trouble
I need some help I have a 2004 Aquatrax f12x, and right now it will not start or turn over at all. It was running on land for a little bit, and all of a sudden it just shut off, and it did not feel as though it had overheated. Now after I have changed the oil and put it together, It will not start. Did I trip a switch or the ECU or anything? How can I reset this?
stessier is offline   Reply With Quote
Old 05-25-2011, 02:01 PM   #2 (permalink)
Are you sure the battery terminals are tight and the battery charged? Check your fuses. It may be the main relay that is hidden in the rear beside the big black electrical box. You should not run them more than 30-40 seconds without cooling water. Always shut off the water before you shut down the engine or you might hydrolock the engine.
Old 05-25-2011, 02:03 PM   #3 (permalink)
glockm22's Avatar
You had to of disconnected something when you changed the oil, take your time and look around and I'm sure you will find it. Hope you didn't run it with out oil? it will lock up. If I understand everything your saying
-- Confucius
Old 06-03-2011, 09:56 AM   #4 (permalink)
pepe-2327's Avatar
First of all, you should not run the engine on land too long, it is not good for the it (I was told 2 or 3 min max), even with water running. I had the same problem, I was flushing and cleaning one of my Jetskis, turned off, and then did not want to start again. It was a 5 amp fuse that was completely rotten. so take a look in the fuse box. Good luck
pepe-2327 is offline   Reply With Quote
