My 04 F12X does this also, it is usually caused by Heat soak! depending on the octane of your fuel, air temp, and water temp, this will happen. The hotter it is the worse it gets. One way to be sure this is not the problem is to up the octane in your next fill up. try and find some race fuel, 100 octane and mix with 93 premium fuel. If you find that you are able to stay WOT longer then this is your problem. Adding an IC helps immensely and allows the boost to stay on longer.
06 R12X Macsboost, filter, wedge, IC. Solas ,intake,
04 F12X
