2006 f12 engine flush - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-21-2011, 10:17 AM   #1 (permalink)
Default 2006 f12 engine flush
I just bought 2 06 f12's. Can I move the engine flush hose to under the back seat or is this also the engine water pick up
foolishpursuit is offline   Reply With Quote
Old 06-22-2011, 11:23 AM   #2 (permalink)
It is a main cooling water outlet [when in the water running], don't move or restrict it or it will overheat.
Old 06-22-2011, 01:38 PM   #3 (permalink)
Thanks The reason I wanted to move it is I keep mine on a floating dock and can not get to the flush. Would think Honda could of came up with a better idea. It's fine if your on a traier.
Old 06-22-2011, 02:57 PM   #4 (permalink)
That makes a lot of sense. I have friends who left their on floating docks and the inability to flush and the salt air surrounding them destroyed them. I bought three F12Xs like that from a guy in Savannah that thoroughly trashed them on the end of his dock in two years time.
Maybe you can make a longer 1" hose with a reduced neck/clamp that would restrict the flow. Make sure it is running while you flush or you'll push water into the engine.
Old 06-23-2011, 05:51 AM   #5 (permalink)
I guess I'll go see my Honda mechanic and see if we can't increase the hose size as to not restrict flow, add a tee and a shut off valve behind it again thanks for all the help
Old 06-27-2011, 10:36 AM   #6 (permalink)
glockm22's Avatar
I would suggest pulling it out and flushing it, and inspect your ski, always a good idea to protect your investment. Wouldn't ya think? Also grease the bearing and wash well so you don't get corrosion. Just my opinion.
-- Confucius
Old 06-27-2011, 11:14 AM   #7 (permalink)
I wash and flush every time I use the ski's. But with the rear flush I now have to wade out waist deep to flush them. With my old yamaha's all I had to do is lift the seat and plug into the built in quick connect. It's nice to have the ski's here at the house instead of having to go 5 miles to a ramp.
Old 06-27-2011, 11:37 AM   #8 (permalink)
Is this salt water? Fresh water does not need a flush very often.
Old 06-27-2011, 02:34 PM   #9 (permalink)
Salt/brackish Chesapeake Bay
