Grinding noise, vibration in rear ? help !!!!!!!! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-23-2011, 09:00 AM   #1 (permalink)
Default Grinding noise, vibration in rear ? help !!!!!!!!
Sorry for my bad english,im french canadian :S I have a r-12x 2004 and when i run over 20 mph i hear a noise like a vibration or grinding song in my back rear and i dont know what is this probleme !! But.. never when i push the gas or acceleration !! The worse moment its when i drop the gas very slowly (60 to 40 mph ) . I have put grease in the plug in back with a grease gun and no improvement Me i think the shaft is tongs or the impeller is twisted !! The impeller bearings seems good but i will change all , i have call on ebay a jet pump, a impeller solas , bearing kit with the seal . I need you to find my misterious probleme ???
Thank you
AQUATRAX R-12 X is offline   Reply With Quote
Old 06-23-2011, 09:39 AM   #2 (permalink)
p10sdad's Avatar
Originally Posted by AQUATRAX R-12 X View Post
Sorry for my bad english,im french canadian i hear a noise in my rear
Thank you
A noise in your rear huh? Check the impeller shaft, to see if its bent at all. Go through and tighten up the nuts and bolts in your rear
Old 06-23-2011, 10:27 AM   #3 (permalink)
Ok i will check that, thank you !! And if i change the shaft, is it very complicated and does long to change?
Old 06-23-2011, 03:08 PM   #4 (permalink)
p10sdad's Avatar
IF thats what it is, it's doesn't take long, and is a pretty easy deal. That may not be it though, its hard to tell over the computer, so just check it out.
Old 06-23-2011, 06:31 PM   #5 (permalink)
Ok thank you for this information !!
