2005 F12X Turbo Humming Noise - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-07-2011, 07:25 PM   #1 (permalink)
Default 2005 F12X Turbo Humming Noise
Has anyone ever experienced hearing an electronic humming noise after the jetski is turned off? I had to disconnect the battery because I was afraid it would drain the battery. I let it go for about 10 minutes and it never stopped. I disconnected it and it stopped until I started it again then the same thing happened. Thanks.
stuntmanmd is offline   Reply With Quote
Old 07-08-2011, 08:42 AM   #2 (permalink)
You have a bad Main Relay, do a search here or in PWCTODAY.COM in the Honda forums for the info on it.
Old 07-09-2011, 04:55 PM   #3 (permalink)
Default Follow on
Can I nurse it along for this season and replace at the end of the season... if I disconnect the battery after each use? Thanks.
Old 07-09-2011, 07:30 PM   #4 (permalink)
If you don't mind be stuck out in the water when it completely fails....
