Just in case someone else has the same problem to fix GPS just make sure the PWC is outside with a clear view of sky. Then disconnect the negative battery cable for a couple of minutes. Reconnect the negative battery cable and this will reset the GSCAPE (GPS) system. Fixed my problem.
