Honda leaving oil water mix in bottom of jet ski - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-21-2011, 07:58 PM   #1 (permalink)
Default Honda leaving oil water mix in bottom of jet ski
I have a Honda jet ski 2004 Aquatrax R12. The engine runs fine but after a ride inside the hull on the bottom is a creamy mixture of oil and water. It will have 3 or4 cups.
Does anyone have an idea whats going on?
RB
Ron Bierman is offline   Reply With Quote
Old 08-22-2011, 02:21 PM   #2 (permalink)
If you have a lot of corrosion you could have a hose leaking under the engine. Check your oil filter and oil pressure swiches under it for leakage. Make sure the O ring is on the rear bottom oil check plug.
Old 08-27-2011, 08:07 AM   #3 (permalink)
Default oily water in hull
I can't find any evidence of an oil leak.
