2004 Honda Aquatrax R12 quits running during a ride - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-22-2011, 05:53 PM   #1 (permalink)
Default 2004 Honda Aquatrax R12 quits running during a ride
During a ride on 2004 jet ski r12 it will up and quit. You can disconnect the landguard and then plug back in and it will start back up and run again. You can be riding for 30 minutes and it will quit again. It always starts back up when you remove the landguard and put it back in.
What is goin on with the electrical system?
Ron Bierman is offline   Reply With Quote
Old 08-24-2011, 12:51 PM   #2 (permalink)
glockm22's Avatar
do you get any codes on the dash? any warning at all ?
-- Confucius
Old 08-24-2011, 03:05 PM   #3 (permalink)
Sounds like a low oil pressure trip or the MST tripping.
Old 08-27-2011, 07:40 AM   #4 (permalink)
What is "MST tripping"?
No codes are showing on the dash.
Old 08-27-2011, 10:27 AM   #5 (permalink)
The Manifold Surface Thermostat is an instant shutdown and just gives you the thermometer Icon on the display flashing. It does not store a code once the laynard is reset. Same with the Hi/low oil pressure.
Read my post "30 minutes can save you thousands" on the Honda forums to PWCTODAY.COM
Old 08-28-2011, 07:28 AM   #6 (permalink)
Default MST check
Is there a way to check the MST whether it's failing?
Is there a way to check the oil pressure gauge?
