STX 1100 wont start, hoses hooked up wrong - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-24-2011, 08:15 PM   #1 (permalink)
Default STX 1100 wont start, hoses hooked up wrong
Hi Guys,
Had My STX sitting around all winter now its time to get it out it wont start,
Couple problems, some how ( I have no idea) the hoses were hooked up wrong Pulse and supply were back to front.
also in the manual its says to prime the machine pull off the return line and blow through it until fuel comes out the return barb. When i do this it just pressurizes the tank. this doesn't seem right, am i doing something wrong?
It has spark on all 3 cylinders and 130psi per cylinder, i changed fuel filter. And at last service the accelerator pump was inspected and in great condition.
Could the line pulse line be full of fuel and not be pulsing the accelerator pump?
any suggestions would be great thanks
Craig
CrAiGzEE is offline   Reply With Quote
Old 10-13-2011, 04:51 AM   #2 (permalink)
anyone got any idea?
Old 10-13-2011, 11:56 AM   #3 (permalink)
Hoses don't change locations by themselves.... are you sure about how they were, and how they now are???
When you do the "priming" procedure, you do blow into the return line that goes back to the tank, and yes you do pressurize the tank (Tank cap is on tight). This should drive fuel out of the tank via the feed line, which routes through the gas valve (you did turn on the gas valve didn't you?). It then flows into the carbs via the supply hose, and upon filling the carbs, it starts to overflow out the carb return hose barb. There is some resistance as the fuel flows thru very small orfices and in-carb filters.
If that didn't happen, then pull the supply hose off the carbs and verify that the fuel is flowing out to that point at least.
If the hoses were indeed reversed, I doubt any damage was done, but it could not have possibly ran that way.
The pulse line cannot stay filled with fuel, (it would drain out, or be evaporated) and it wouldn't matter as the pressure variations (pulses) would still be transmitted up the hose.
Your problem could be clogged in-carb filters. Do the plugs indicated dry, or flooded, conditions? Will it fire-up momentarily with manually primed gas (pour it down the carb throats). I believe that ski has 2 fuel pumps (front & rear carbs), and even one working should get you enough fuel to start it up.
