Originally Posted by ricogear
Not long ago rebuilt my engine out of my ZXI 1100. Have had a over heating problem on 1 cylinder. New exhaust manifold gaskets only have small round holes. Should they have holes the same size as the ports on the manifold & head? Anybody know?
is it getting hot when running off the hose or is it getting hot while riding .i would sit the ski in the water on a trailer is fine at the marina and then moniter the temp . if you cant do it this way try and run the hose off the water inlet hose at the jet pump NOTE the flush is only to back flush not a cooling aid
the gaskits do have small holes to evenly space the water out also you dont want to much water flowing through as this will cause over cooling and primiture wear
my 900 zxi use to get hot on cyl 1 due to gaskits having silocon on them and blocking the hole i renewed the gaskits and it still got hot but not as hot it was before and the ski runs fine in water
i do notice #1 gets hot when running off the hose due to all the water running into the exaust pipe and very little water makes it to #1
