Old 08-22-2006, 10:26 PM   #1 (permalink)
bigred73
Question kawasaki 550sx
I recently installed a stator in a 91 kawasaki 550SX, now it barely idols, and when you get in the throttle it dies out. I've tried to switch carbs from another 550, same thing. I've used an external gas tank and line to make sure it was getting fuel, same thing. I've played with the low and high idol screws and got it to run a little better, but it still dies out at high idol. Could some one shed some light on this problem?
bigred73 is offline   Reply With Quote
Old 08-22-2006, 11:38 PM   #2 (permalink)
Knightofwyte
Knightofwyte's Avatar
What condition is the engine in? I'm assuming that it ran prior to the stator install...
Have you verified that everything was reconnected and that everything is adjusted correctly? Sounds to me like this is a spark and/or timing related issue.
Old 08-23-2006, 12:19 AM   #3 (permalink)
bigred73
it ran good before, lost spark, installed rebuild stator, I'm questioning one ground wire which I will replace tomorrow. not for sure on how to time the engine?
according to previous owner a lot of engine work was done to make this ski scream.
Old 08-23-2006, 12:32 AM   #4 (permalink)
Knightofwyte
Have you checked the CDI? Where did you get the rebuilt stator from?
I would go ahead and test the stator if I were you. If the CDI and ground is good then it's probably the exciter in the stator. It's not unheard of for rebuilt stuff to be defective, look at SBT!
Stator Test:
green to black: 1.2-1.8
green to green: 2.4-3.6
red to black: 112-168
red to grey: 14.4-21.6
Still you need to verify your wiring and make certian you have good connections everywhere.
Old 08-23-2006, 05:48 AM   #5 (permalink)
JUST-IN-TIME
JUST-IN-TIME's Avatar
Talking 550
did u static time it
are u sure it was a good stator
do u have a manual to to the testing?
Old 08-23-2006, 08:44 AM   #6 (permalink)
Knightofwyte
Ok, I missed where you said you didn't time it...
You should do that as well, I'm at work currently so I don't have a manual nearby to verify timing directions. Lets see if Ocean can remember how to time this thing!
Old 08-23-2006, 08:47 AM   #7 (permalink)
Knightofwyte
Edited:: Ignore this....
Old 08-23-2006, 08:49 PM   #8 (permalink)
JUST-IN-TIME
Exclamation
all i can remember is that when u put the stator on u line it up with the mark on the cases. u need a piston stop to check for TDC. u put the flywheel on and look t what numbers line up with the mark. it should be 25 i think i can not remember and do not have my manual over here where i go to school so it is a crap shoot
u adjust idle timing first, then WOT timing
to adjust u need to looses the 3 screws on the stator and rotate it
MAKE SURE U PUT LOCKTITE ON THE STATOR SCREWS OR U WILL BE SORRY
TRUE JACKASS FISHING REPORTS
Old 08-23-2006, 10:13 PM   #9 (permalink)
bigred73
I lined up the marks on the stator but that was it. I'll go threw and redo the stator, and timing and see if that helps.
the previous owner didn't locktite on the screws and this is why I have it.
Old 08-24-2006, 12:12 AM   #10 (permalink)
JUST-IN-TIME
Question 550
cool let us know
u have a manual right
vB code is On
