Originally Posted by jondjon101
Please can someone help me as I'm running out of ideas and places to look. I have a 440 which I have rebuilt the engine. It starts fine out of water and works for about 5 minutes in the wtare then cuts out. It wont then start until the next day! I have check the plugs and they are fine, Compression test on each cylinder is about 110. There doesn't seem to be any water in the engine when it cuts out (spark plugs dry just a bit dirty). I have a primer that pumps fuel to the carbs ok. It is throwing me that it works for a while and then stops suddenly and then wont start for a day. Any ideas on where to look/start would be gratefully recieved as I would like to try and get some serious time on the water. Thanks
Check for spark after it quits running.... That would be a good start... If it sparks, then check for fuel. If you have both and it won't start.. Dunno...
If it doesn't spark, That's way over my head in diagnosing....
One of the experts may have to intervene..
Good Luck.
