2003 kawasaki sxr possible seal leak???? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 02-21-2009, 09:50 PM   #1 (permalink)
Default 2003 kawasaki sxr possible seal leak????
i have a 2003 kawasaki sxr 800 i recently pulled the plug on the stator casing and the bottom of the plug was a bit dirty with sticky oil like resdeu is this a possible indication of a crank seal leak??? should i be worried it seems to still run fine
2003.kawi.sxr is offline   Reply With Quote
Old 02-22-2009, 07:12 PM   #2 (permalink)
JUST-IN-TIME's Avatar
time to do a leak down test on the block
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 02-25-2009, 06:34 PM   #3 (permalink)
soo i did the test its deffintly leaking a bit so i pulled the motor and the case on the stator side of the engine.. but stop there because i didnt wanna pull the flywheel without knowing if im gonna mess the timing up i see a mark on the flywheel should that be lining up with something, when the stator side cylinder is at tdc ??
Old 02-25-2009, 06:38 PM   #4 (permalink)
stator is under flywheel
you will not mess timing up until u pull the stator
Old 02-25-2009, 08:03 PM   #5 (permalink)
so i can put the fly wheel back on in any position? the stator was mounted to the case i removed...
Old 03-01-2009, 05:01 AM   #6 (permalink)
flywheel has a key way on it
