jet pump interchange?
I have a 2001 900STS that needs a new jet pump. Does anyone know if different yrs will interchange?
thanks in advance for any advice!!!! The old pumps bearings went bad, the impeller is worn down about 3/16 of an inch & the stainless wear ring inside the housing appears to galled, a new impeller won't fit...can the housing be machined or honed to the proper size again?
