96 STS 750 driveshaft seals - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-03-2009, 07:29 AM   #1 (permalink)
Default 96 STS 750 driveshaft seals
Hello,
Question is, I am getting water into the hull and Im thinking it is the driveshaft seals. What kind of job is it to replace these? Are there special tools needed? any help would be great Thanks Randy
randy16365 is offline   Reply With Quote
Old 05-04-2009, 10:29 PM   #2 (permalink)
You need to unhook the exhaust, pull the motor,slide the impellor shaft into the hull, the bearing holder is held in with 4 bolts if it is cracked replace it. if not undo the internal circlip and change the bearing and seals, use lots of grease when reinstalling them. Note: if this bear ing is bad you probably need impellor housing bearings too.
fleshbazbo is offline   Reply With Quote
