Kawasaki 750sx starting problem and running full throttle - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-17-2009, 01:10 PM   #1 (permalink)
Unhappy Kawasaki 750sx starting problem and running full throttle
I have a 93 Kawasaki 750sx. Just yesterday I had to keep the choke on while running it and if I went full throttle it would die. If I wanted to go faster I would have to open the choke by one notch, it still would not go full throttle. Then it just stopped in the water and wouldn't fire up (it did turn over). I thought it was a carb problem, so I completely took apart the carb and it looks clean. There is only a little scum on the choke valve, I didn't think it was a problem so I left it. I took apart the jet and cleaned the micro filter near it.
I also put new spark plugs in it. It turns over but does not fire up. Also usually when it would turn over small puffs of exhaust would come out, but that's not happening.
borabora2go is offline   Reply With Quote
Old 05-17-2009, 01:22 PM   #2 (permalink)
JayDawg's Avatar
Stupid question but what did your old spark plugs look like when you pulled them out? Also, check your lines and make sure you have no water in your fuel or that there is no fuel or vacuum leaks any where.
Old 05-17-2009, 01:29 PM   #3 (permalink)
Unhappy
They had grey/brown stuff all over the sparking area. They are the third set I have put it in two weeks. I did put lower grade mixing oil in the fuel
Old 05-17-2009, 02:10 PM   #4 (permalink)
JayDawg's Avatar
I am familiar with your model of stand up ski but I do not remember, do you have to premix the oil or is it injected? That could also be a factor is a bad mix or your oil injection could be malfunctioning.
Old 05-17-2009, 02:51 PM   #5 (permalink)
Yes, I premix at 40:1, I ran out of the good oil so I put it a different color and lower grade oil in the same tank. But shouldn't it fire up just not run as well? Its not even turn on (but does turn over).
Old 05-17-2009, 03:24 PM   #6 (permalink)
I now can see exhaust come out and I can smell gas in it.
Old 05-17-2009, 03:30 PM   #7 (permalink)
JayDawg's Avatar
Exhaust coming from where?
Old 05-17-2009, 03:49 PM   #8 (permalink)
The exhaust pipe, there was noting coming out before I took apart the carb. What do you think is the problem if you had to say?
Old 05-17-2009, 03:55 PM   #9 (permalink)
JayDawg's Avatar
Since you have a 2 stroke motor, you should have exhaust coming out of it. You should see my Ultra 150 when it is running out of the water. It smokes bad. My 750 SXI is not as bad but seeing the exhaust come out is normal.
Is your ski starting up now?
Old 05-17-2009, 04:01 PM   #10 (permalink)
turning over yes, starting up, no
